OZ newbie LPG Problem
Hi i'm a newbie here,
Just get my self a '91 LC, 3FE 80 with dual fuel (petrol/LPG). LC won;t start (just cranking) if i switch it to LPG (Engine stop if i switch from petrol to LPG when running)
is any one familliar with LPG installation? Can you help diagnose this problem .... Thank You :cheers:
i checked all the fuses at the engine bay and under the stering wheel. is there any other place i should check for the Fuse? or something else ?
Many of the folks around here are from the US, where we don't get the dual fuel setups. :(
Just curious, but how much did it cost you and who did you have set it up?
Anyway, my first thought is that you're not getting fuel from the LPG. Can you test your flow some how?
I have a dual fuel 80 as well.
The way mine works is that it starts on Petrol and then switches over to lpg. If it's already running on petrol and I want to switch to lpg I need to press the accelerator when I switch it over. Going from lpg to petrol is no issue, just flick the switch. Have you got gas in there?
If I am low on lpg sometimes it takes awhile to switch from the initial petrol startup to lpg.
Thanks you for the reply.
Ebag333, i dunno how to test the flow. it looks like the Gas not flowing. ut it works fine until last week. get the car with dual fuel fitted. here in Aust, we got Goverment grant ( $2K + return) if we convert the car from petrol to LPG, last time friend of mine spend around 3K after refund they only paid around 800-1K.
joedm, the tank full. and mine not auto like yours ..i have to flick the switch even on startup.
i was hoping is just the fuse from the switch to the control (if there is one) may be blown ....
:confused::confused::confused:
No Idea bout the LPG but Welcome!:flipoff2:
I'd take it to a lpg mechanic to have it looked at.
It may be something small which should be fine and not cost too much but if it is something big then you'd want a pro looking at it.
To me it sounds like an electrical fault... maybe the switch ... but I don't know what I'm talking about..
There are a few bits to check but best left to a LPG mechanic. There is a fuel cut off sensor that looks for a signal from the ignition that turns on the LPG at the soleniod it's a safty feature. There should be a solenoid at the tank and at the gas converter. So if the engine stalls or cuts out the gas supply is cut.
Coolant level can also be a problem, not enough water in the system and the gas converter can freeze as a result.
None of these issues are expencive to repair, unless its the gas converter itself.
But at the end of the day duel fuel is a compromise I prefere stright Petrol for my 2F-ETI ;)
Its probably a faulty safety switch. Look for a matchbox sized plastic box which on most 80's is fitted above the shround under the steering wheel. It will have a ground wire, power wire and a wire that goes to your coil/distributor. 99% of them have a single LED that light up everytime you have the LPG turned on whether it is cranking or running it should always be on when switched to LPG. If you can locate the box and see the LED and its not on then just replace the box(safety switch). They cost around $40 and are all wired similar, only difference is some earth themselves through their attachment screw and others require an earth wire. It will take you about 10 minutes to replace it.
