Oxygen Sensor Problem with CEL
Hello
I finally started my '91 FJ80 but it is running rough.
I had two errors on the ECU. (CEL)
I had code 21 and 28.
Both are oxygen sensor faults.
I found a broken wire on an oxygen sensor and repaired it.
Now I get code 21.
The problem:
There is only one oxygen sensor and only one connector.
I looked and looked and there isn't another connector.
WHAT'S WRONG!!!! :mad:
You should have 2 O2 sensors, one for each pipe.
(At least IIRC, I'm not as familiar with the 3FE's....)
That's what I thought.
I can't seem to find the other O2 connector.
I bought the engine used from someone in NC because the original engine seized.
The engine came with the engine wiring harness but I used the connectors that were on the truck.
I just took a look at the harness that came with the engine I bough and it too has only one O2 connector.
They should be together, right?
I solved the problem!
I found that the ECU wires run across the dashboard and to the driver's side.
They go up into the front.
The oxygen sensor wires are supposed to go down on the firewall to the exhaust.
The previous owner had cut the head and pushed the wires underneath the windshield fluid reservoir.
I had really wished for a little more help from the IH8MUD community.
:confused: What is it you wanted from us??
Maybe "My O2 sensor wires run underneath the master cylinder."
If I would had gotten a small lead I would have solved the problem a long time ago. But Oh well :frown:
I'm going to fix the wires as the previous owners had cut the head.
Hopefully everything goes good.
Sorry, but a lot of us haven't had that particular problem, or any other reason to know where the O2 sensor wires ran.
I would have been clueless myself had you asked. That's just one of those things that rarely (if ever) comes up. :meh:
