oxygen sensor color codes
I know this is an easy fix for someone out there. I'm replacing a bank 1 Sensor 1 oxygen sensor on my 1996 Lx 450 with a Bosch oxygen sensor (15728). However, color codes for wiring don't match the sensor I took off. None of the color codes I've looked at match what I have. Maybe the sensor isn't OEM? My sensor has 2 black, white and blue wires while the replacement has 2 white, black and grey. I've been using the trial and error method and figured someone could save me the time. Thanking you in advance. :)
I would not recommend using bosch. They are not genuine OEM and do not work well in this vehicle. I used a bosch and it never worked correctly so I ended up buying two OEM Toyota sensors from CDan. They work perfectly and snap right in with no guess work. Sorry I can't help you on the color codes.
I am with Nick and just installed 2 new Toyota O2 sensors this afternoon. 1 banana job since my truck lives in the Southwest and there was no issue with removing (and reusing!) the nuts. The rear sensor even has the correct plastic stay that plugs into the frame just like the factory O2 sensor. No splicing of wires and no hack job.
However, if you insist on using those Bosch sensors or for some reason you cannot return them, then I know there is a thread that discusses how to wire them. I will search for it if you need it... just let me know.
If you want to do the searching, try O2* sensor + blue + black (or white) or something like those keywords (maybe use "splice" as a keyword). Be sure to search ONLY in the 80-Section; all authors.
Here is SUMO's O2 sensor thread on using Bosch sensors in his 94. He states the ones he used will not work in your OBD-II vehicle. https://forum.ih8mud.com/80-series-tech/118555-o2-sensor-replacement-1994-fzj80.html
You might contact beno (97 LC) to see if he ever resolved why his Bosch sensors were throwing codes. He might have worked out the wiring for the Bosch sensors.
Good Luck,
-B-
Do not waste your time with the Bosch O2 sensors for these trucks... I have reported the non-solution to a fellow engineer who specifically works on O2 sensor production and development at Bosch in Anderson, SC. I will post up when I hear something back from him.
I know this is an old thread but I feel compelled to reply to it since I found it via google anyway. You don't necessarily have to use OEM o2 sensors purchased at the dealership, one effective way to buy such parts it to find out what the OEM used as their supplier. For Japanese cars, they typically use Denso or NGK for their parts. The reason you want to find out the original supplier is because they have the patent rights to the OEM parts so they can faithfully produce those parts to OEM specs if you purchase the parts directly from them or at a retail outlet that carries their parts. In the case of my Toyotas, all the the sensors I've seen have been Denso, so I just go to the denso website, find the correct part number, then google the part for the lowest price, and I usually end up at amazon.com.
If you do it this way, you'll get OEM parts at aftermarket prices.
