HI there! sorry for my bad English I have trouble with my TLC 80 94.
Diagnostic cel code 21-28 mean "bad oxygen heater" ok, i buy two 89465-69085 for 260$
my old oxygen sensors were not identified ( i think its OEM parts)
old oxygen wiring color > gray, brown, white, blue,
new oxygen wirig color > black, black, white, blue,
plug in the new sensor is different from the old men just replaced plug
i found this thread https://forum.ih8mud.com/80-series-tech/118555-o2-sensor-replacement-1994-fzj80.html
O2 wire Color Code Mr. T - OE
Blue = Signal wire
White = Heater wire 1 (non polarity)
Brown = Heater wire 2 (non polarity)
Grey = Aux Ground
O2 wire Color Codes: Bosch 4 wire sensors use the following code:
Black = signal wire
White = heater wire (non polarity)
White = heater wire 2 (non polarity)
Grey = Aux Ground
Ok, the obvious (T = toyota B = Bosch):
T - Blue > B - Black (MOST IMPORTANT)
T - White > B - White
T - Brown > B - White
T - Grey > B - Grey
O2 wire Color Codes: Denso 4 wire sensors use the following code:
Blue = signal wire
Black = heater wire (non polarity)
Black = heater wire 2 (non polarity)
White = Aux Ground
Blue = Signal wire
Grey = Aux Ground
Black = signal wire
Grey = Aux Ground
T - Grey > B - Grey
Blue = signal wire
White = Aux Ground
is that correct?(T = Toyota D = Denso):
T - Blue > D - Blue
T - White > D - Black
T - Brown > D - Black
T - Grey > D - White
