overheating problems on chevy350
Brownsville,Tx.
I have a 1979 fj40 with a chevy 350. the problems I have is overheating. running from 210 to 220 in a very little time. small mod to the engine but causing overheating. I have a mild cam for torque purposes which also give me a hotroad idle. I like it but I am regreting it. Iam running the stock radiator with an electric fan, you could say it is as big as the radiator. I put a 180degree thermostat did not help. the radiator was clean and flush before installed.
what kind of radiator would help? are there any others cheaper then the aluminum that cost from $350.00 to $500.00 any suggestions are welcome. I dont want to sound cheap but price conciensous.
I have a '74 FJ with a built 350, stock water pump and stock fan. With a stock radiator that was cleaned before installing. But I have made a custom fan schroud that completly surronds the fan. The motor goes to 180 quickly but has yet go any higher. I think the schroud is the main item that has saved me from any problems. So maybe check to see if you are pulling enough air through the radiator.
MILD 406 sbc, stock pump, no thermostat ( havent had one for yrs), stock cruiser radiator, Tauras fan, Never see above 200 (damn adjustable temp switch has like a 10 degree area to kick on). Run around on low speed all yr only on days above 90 out do i have to run with high speed, and it still cycles on and off.
Make sure you run the 1 3/4 bottom radiator hose (this alone was 10 degrees over a 1 1/2 hose) and the spring in it.
Check your timing. also sounds like to much cam, IMO about 214 duration @ .50 is about most in a off and on street cruiser, I ran one cam bigger 224, and it sucked ASS. Well if its built for high RPM highway i could see a large cam, but snail off the line.
I'm fond of the aluminum radiator I got from Dirttrackthunder on eBay. I think it was $135 when I bought it, but I seem to remember it went up since.
The shroud is very important if you overheat while at low speeds. If at high speeds it might be a flow problem. Does your engine run OK? a lean condition will make it run way too hot as well.
Install a large aluminum radiator and fabricate a fan shroud. Use the stock fan with clutch if possible. Flexalite fans don't work very well.
I am thankful for your response to htis matter I will look in all the options. everyone seems to agree in the fan shroud. the cam is not that hi is 204 but tthe heat is intense. now I forgot to mention that I am from Brownsville tx. and the heat here is hot
