Overall Lift Database
San Diego
We started polluting a picture thread with some numbers to compare overall lift. This topic really deserves its own thread.
Overall lift measuring from ground to fender lip as this is easy to measure. Includes tires, suspension, and potential body lifts.
Figure this would be a great reference and database of various modification combinations. If you want to get in on the action, post your numbers and I'll add it to this table. Please also post relevant "lift" mods. Maybe even a picture.
Ground to fender height
FrontRear
@MTKID - LX570 on 37s, Body Lift, Sensor Lift, (AHC high)43.5" (with 2" cut fender)
41.5" (normalizing for fender cut)
42.38"
TeCKis300 - LX570 on 35x12.5R20, Sensor Lift, (AHC high)38.38"40.5"
@turbo8 - LX570 on 285/75R17, Kings 3.0 (AHC delete), no seats, full tank gas38.25"39.25"
@sdnative - LC on AT3 275/70R18, Bilstein 6112 on 1st (lowest) perch, OME 2721 rear. Half tank gas. ARB drawers w/ ~100 lbs contents36.13"37.38"
@MikeVpdx503 - LC on LT285/70R17, OEM front leveling spacer35.75"36.5”
@Steveray450 - LX570 stock36" (high)
33.5" (normal)
31.5" (low)
38" (high)
35" (normal)
33.5" (low)
LC200 on 285/70 17's with Dobinson IMS C59-542 2" front spring and C59-535 2" rear spring 38" Front 39 1/4" rear
Mine is 38.25 front 39.25 rear. No weight of seats, full tank of gas.
* Icon progressive rear springs (claims 1.75" higher ride height) and tundra front components which should effect things. 285-75r17 bfg ATs.
^Thanks for the data points. Added!
2013 LC. Bilstein 6112 on 1st (lowest) perch, OME 2721 rear. Half tank gas. ARB drawers w/ ~100 lbs contents
Toyo AT3 275/70R18 @ ~45psi
Measurements (FL, FR, RL, RR):
Center of hub to fender lip - 20 1/2, 20 3/4, 21 5/8, 21 7/8
Ground to fender lip - 35 7/8, 36 1/8, 37 1/8, 37 3/8
