over heating on hwy?
Copperhead Rd.
I'm looking at buying a late model 40. The seller told me the truck over heats after about 2-3 miles on the hwy @ 55mph. He said he checked all of the usuall suspects and all was fine. He also said that it doesnt seem to be all that hot although the temp guage says different. Do you think the gauge is just bad, or am i looking at a head gasket?
Your water jacket may be stuffed with debris, or your radiator may be plugged. You need some objective information (is it real, or does it just have a defective temp detector).
He said he had the radiator rodded out. He also drives the rig around town with no problems.
well the jackets might get clogged in the cylinder. its seems to me that on the highway it would do fine but in town it would overheat due to the lack of air unless he was running a super high RPM....
over heating
Chronic over heating is really bad for your engine. It can be checked with a heat gun. Often hoses are to blame. But check for oil in the coolant etc to rule out those issues. If you change the hoses especially the discharge hose and do not see an improvement you may need shrouding or an electric fan. I also put in an aluminum radiator. Engine failure is very likely if this is chronic.
Water pump cavitation? Try a new radiator cap. If the system isn't under adequate pressure, the pump will cavitate. Pumps cavitate worse at higher RPMs.
Assuming your radiator is stock and your engine has no other reason for running hot, this is really the only solution that comes to mind.
Addition: what does your temp read while crusing around town?
Many of the proposed diagnosis would exhibit symptoms during an extended period of city driving as well as highway driving. Failed thermostat, collapsed hose, bad shroud or an extremely clogged radiator would probably run hot (if not hotter) at lower RPMs.
Remember, even though your engine is producing more heat while at high RPMs on the highway, you have a lot more airflow (radiator is much more effective, shroud is non-issue, etc.).
Check your fan clutch - my 79 FJ40 ran hotter than I liked at interstate speeds and cooler around town - just as you describe. I too had a new thermostat, coolant, belts, hoses, radiator, etc. First problem was "burping" the engine block of air in the system (easy enough to do) and that made some obvious improvement - wasn't until I changed the fan clutch did the truck run as cool on the highway (60-70 mph speeds) as it does around town.
Hose collapse can happen at a higher rpm due to increased suction and return to normal at idle. Some hose applications have a coiled reinforcement wire in side to prevent this. Weak hoses can be a problem too. Not a common problem but it can happen.
Interesting. Haven't ever seen it though it's quite plausible.
I thought the stainless coil was standard in most lower "suction side" hose. Is this a newer practice?
Next time I replace my hoses, I'll have to jump on 'em :) . On second thought...
I think it's been around for a while. I can remember seeing hoses like that on some of my earliest cars. We won't go in to how long ago that was. :D
I've seen other than stainless wire used. (rusty bits falling out of the hose) I think the factory applications were precations against know potential suction issues.
any hose can collapse, run all hoses with wire in them, if yours dont pull the old wire out of the hoses you take off, and put them in the new ones. Dont ask how i know.
timing?
always open heat vavle when re filling the system and run it.
I was guessing timing too. I'm just going to have to go look at it for myself. I can always flat tow it home after I give him about $1500 less than he is asking.
