output shaft change
I need to change the output on my 4l60E for the AA adapter kit. I Feel very confident in most mechanical abilities, but i have never torn into an auto tranny. Would yall say this is no biggy or that i should definently take it to a shop?
I have been through many a manual tranny, I am not an auto guy, and would take it to a shop.
You could get a book on it, tear it down, and change the shaft out. The whole tranny does need to come apart. I would have them go through it while it is apart too, but that is just me....I know an auto guy that I trust, and it is not worth my time to learn them right now.
Good luck!
-Steve
This is gonna sound dumb, but I think that Auto trannys are easier to work on than a stick shift. I have redone a couple TH's and a Dodge auto. The biggest thing to remember is take everything out and lay it in an exact order. I flip every piece over face down, that way I know what direction everything is suppossed to be in. Autos have all kinds of fun stuff like grooved washers, which means if one gets flipped over the wrong way... you will burn it up. Oh ya and if you decide to do this, don't tear apart the valve body unless you know where it all goes. I won't do one unless I have the factory service manuals for that tranny. Have fun
With the service manual you should be able to do it. That being said, it's very easy to put something back wrong, miss engaging the clutches, or tear a seal, and you won't know it til it's too late. If you take your time, have the proper tools (snap ring pliers, pump puller,...) and have a CLEAN area to work in, it can be done.
Good luck.
