I did my J's and L's lift 2 weeks ago. My HDJ81 has the factory winch and the heavy diesel engine so I needed 30mm front coil spacers to get it looking a bit closer to level. Once I throw 300lbs in the back it will sit level.
Brake Lines: You don't need to swap brake lines if you're comfortable rebending hard lines by hand. Just carefully rebend the front one and make yourself a short drop bracket for the rear one off the frame. You do need to test to make sure they can't over-extend.
Rear brake proportioning valve: The ratio for determining how much to lower the valve bracket on the frame is just under 16:1. For 4" of rear lift you need to drop the bracket down 1/4". This is dead simple, just mark the bracket's current position on the frame, loosen the 12mm head nuts that hold the bracket to the frame, slide it down, tighten the nuts. You can also mess with the adjuster at the axle end but it is 16x less effective so why bother? In terms of testing, I just slam on the brakes on gravel and if the rears lock up first with no load then I know I went too far.
Diff breathers: I just replaced the hoses with longer ones. It's a good time to clean out the factory breather valves and make sure they work.
Bump Stops: I made myself 2" bump stop spacers for the front and rear out of 2-1/4" aluminum round bar.
Rear sway bar: I cut my rear sway bar links in half and welded in some 3/4" steel round bar extensions with holes in each end to accept the skinny factory links. The truck is infinitely nicer on the road with the rear sway bar in.
Front Sway Bar: I haven't put it back inand don't really plan to. This seems to help the front move better instead of the rear doing all the work off road.
Caster: With 4" of front lift I needed serious caster correction, which I accomplished by slotting the front axle brackets and rotating the axle approximately around its center line then welding washers to the brackets to make the new bolt positions permanent(aka "the washer method"). I knew where it was all heading so I just set myself up for a DC front driveshaft and accepted whatever the caster ended up being. It turns out that it's just under 2 degrees, and it handles very well. Once the springs settle a bit and I throw the ARB bumper on the front it will be perfect.
Driveshafts: Once you correct your caster, you will probably end up with front driveshaft vibration. As mentioned above, I set myself up for a DC front shaft which I will be installing tomorrow. Without it, the stock front shaft vibrates moderately at many different road speeds. The rear shaft is fine.
Rear panhard bar: I paid for a MAF rear panhard drop bracket. It was quick and easy to install, almost centered the axle (with weight in the back it will be good), and I assume it helps with the handling.
Still to do:
front panhard - I will either cut, sleeve, and weld it to the correct length or possibly buy a DIY adjuster to allow for further changes down the road.
front sway bar - I might try using it with drop blocks and quick disconnects to see how nicely I can handle on the road. For now, I'm very happy.
