orion
arkansas
OK, I'm about to install an orion and I want to make sure I have everything I need. From what I have read in the FAQ I will need the following new parts:
Advanced adapters install kit (thrust washers, etc.)
detent ball
High-low shift sleeve (shift collar)
gasket kit
input seal
main shaft (is it input or output?)
Is there anything I am leaving out? Just wanting to make sure so I don't have a popping out problem.
For those Orions that have been retrofitted with the AA install kit and new shift collar, was a new gasket and seal kit needed?
Yes, I did include the shift collar in needed parts. So I have all of the correct parts needed on my list? I haven't ordered them yet, only the orion, so I am wondering if this is exactly what I need. Anything else?
i didn't purchase anything that didn't come with the kit and i have had no problems with it popping out. used all the old stuff. i did have the thrust washers machined down. i may just be one of the lucky ones, though.
Yes, I am going to replace my main shaft. I spoke with Randy at AA earlier and he said that the new orion kits come with the detent ball, gasket kit and input seal. So I guess I only need the mainshaft and shift sleeve (collar). Thanks for the help guys.
Same here. I didn't even need to machine down the thrust washers. FWIW I have case #17
Never has popped out of gear.
I have case #50. I had to use the deepest machined thrust washer to get in to spec. I did not use a new shift collar as my advisers (treerootCO and bh4rnr) did not think I needed one. ;p I also did not use the new shift rail pin provided. I did use the new ball, spring and detent bolt. We'll see how it does, hopefully by this summer. :D
Toyota transfer case main/rear output shaft information:
36231-60011
This is for the early cases (until 04/75) that used a coarse spline front drive coupler.
36231-60012
This is for 04/75 and later one piece Land Cruiser transfer cases. This uses a fine spline front drive coupler.
Note:
(This is relevant to STOCK applications only, NOT ORION cases.)
The pre 1974 transfer cases used a cotter pin and castle nut to keep the parking brake drum on the shaft. The new shaft is an update, and does not use that hardware any longer. If you were to change out a mainshaft from a castle nut to a stake nut, you will need one each of these parts also:
90179-20061 nut
90201-20479 washer
90564-21143 shim
Many Mahalos, Poser.
Will be pulling the Orion and sending the high speed gear back to AA to be machined. They'll be sending me the "kit" along with the gear. Look forward to pulling the booty-fab bungee fix and restoring my rig to her previous glory.
You are welcome.
Talk with Randy at AA if you want/need a shaft....he might have something there for a fair price also...
:beer:
