Orion?
Sacramento, CA
I am looking into buying an Orion T-case kit pretty soon, but I don't know which type I should use, the 10 spline or the 16 spline. I recently just got an Australian tranny, too. 4.95 first gear, and the lady I talked to about it said that it came stock over there, but didn't make it over here. She said it should bolt up to everything stock, so I guess the real question is what are the stock splines for the transfer case? 1976 FJ40, thanks for the help
you should read up on the orion t case . i hear the gears aren't cut right and leave you stuck on the trail.i believe marlin crawler is going to come out with a tcase soon and im just going to wait on it and instead i put my money in a non us h41 tranny which aslo will give you a lower crawl ratio, really low first gear. i dont believe in spending all that money to have it break. i read in some case the owners change the gear oil in the orion and can see metal shavings. i dont know if you have heard of this problem but do the research and im sure you will find many cases. hope you havent bought one yet.
Hi All:
Like it has been mentioned before, you'll need a H41 tranny with the 16 spline 'shaft. I have a H41 bolted-up to the regular "four speed" t-case, and a friend has a H41 that we bolted-up to his new Orion t-case in November, then installed into his '78 FJ40 - the crawl ratio with 4.88s is like 90 to 1!
The only "issues" I've heard of with the Orion is it popping out of gear (into neutral) while descending hills. They quite figured-out with is happening.
Regards,
Alan
Seattle
They don't leave you stuck on the trail but a couple of people have been having problem of the cases poping out of gear during down hill decents from what I understand.
I bought and replaced my high and low slider I figured 60 dollars worth of cheap insurance and I'm glad I did might did have some where, which if you reuse the old one on a new gear might explain the problem.
Another one of my theries is that if the slider is worn from 30 years of use and is reinstalled in reversed on the shaft, you would have the worn spot riding on the low speed gear in low range.
Has anybody looked into this?
I haven't had a chance to run mine off road yet I just put it in this week so my feeling might change but for now I'm very impressed
