Orion Assembly question
Wild Idaho
Helping a buddy install an Orion. When I did mine 2+ yrs ago, I don't remember there being much if any clearance(play) on the idler gear. The bronze washers took up pretty much all the play. A stock Toy case requires a small amount of clearance there, a couple thousandths if I remember right. Does the Orion need that same amount of play? Is less better like it is on the output shaft play?? (I ask, because he seems to have zero free play on his idler shaft, and that seems odd...)
Cheers!
Idler was not in the case, it was in a box! It does not spin freely, it feels very tight. I think we could just mill a thrust washer down a few thou, but what clearance should I aim for? Poser?
Cheers!
What is the # on the Orion case?
There were two in my original seven( 009-015, iirc ) that I ordered that were sent back because the internal bore for the counter-shaft gear was not wide enough to allow the thrust washers and the gear to fit.
Contact Randy at Advance bud.
Post up what you learn.
Thanks!
really, nice that you posted that tid bit a year and half after the umpteen build threads. not even in tree's write up posted on tech was this little detail ever mentioned. nice.
It was not an issue. If I really thought that it would make a bit of difference to say anything about it, I certainly would have. But since they were shipping the cases with the counter gear, thrust washers, counter shaft and o-rings installed, why talk about something that is not a factor and possibly cause confusion with people that only read a little bit of what people post, or create a whirlwind of discussion about something that is not a factor, or have other people spout off about things that they do not have any first-hand information about?
They had stopped shipping cases without the idler gear fitted to the case in ‘04 to make sure that this issue did not exist. Again, the cases that I received were among the very first ones that were sent out. Has anyone else has commented in any way about finding a similar issue? I have yet to read about it.
It is entirely possible that this is an early case that has been sitting around on a shelf for a while until they had the money to do the rest of the modifications to the truck during the install….
In any case….
Please make sure that the high-speed output gear is back-cut like this one:
attachment.php
attachment.php
If either of you have any questions about this, my phone is always on....the number is in the banner add.
:beer:
I left a msg. for Randy, but haven't gotten a call back yet. Will report what he says when I do.
Cheers!
Please post up the case number on the Orion...can be found on the case where the counter shaft is located:
O.K., heard from Randy at AA. The Thrust clearance should be in the .008" to .012" range for a new build. Tighter means binding when it heats up, much looser is not desirable because of excessive fore/aft movement. Case #020 (I think, since I haven't got it in front of me right now) gave me about .003" clearance. No spacer can be removed, it only has the bronze(?) thrust washers on each side. I took it apart, and measured the thrustwashers. They are not real consistent in their thickness. Randy confirmed that this has been AA's experience as well, they don't appear to be a super precision made part. So, what I did was to machine down approximately .003" off each thrust washer. (OK, so I used 400grit paper to take them down) Now clearance is right on. Should complete the assembly this weekend for my buddy, and try it out Monday. He's stoked!
Cheers!
