Organic brake pads??
Spicewood, Texas
I need new front brake pads. Just called the local parts store and all they have are organic pads, no semi-metalic. Do they perform as well. This is an off road only vehicle so I'm not conserned with the added brake dust.
Thanks,
Jeff
I believe they have better stopping power but they do not last as long as the semi-metallic, but then again you won't be needing to change the rotors as aftem as you would if you were using semi-metallic pads. I'm not sure how they hold up to the elements
softer pads also squeek less. If you notice factory pads dont last very long, but they are smooth and quiet. Not sure what compound they use for Toy's but the GM factory pads are soft. I think that it's a good idea, and they should be pretty cheap.
If it is too soft would you then have constant brake dust on the wheels? Never used them either just curious.
I know my wife's Durango had terrible brake dust and would blacken up the front wheels right after a bath it seemed like. ( Durango go bye bye :D )
Travis
I just installed the 'organic' pads on my 85 toy pickup. Autozone offers a 2 year warranty the semi metalic pads and lifetime on the organic? So I got the organic. Will they last a life time? :eek: I doubt it!
I ran a set for 2 years on my 82 fj40, they stoped it just fine, but I switched to some OEM Toyota pads(semi metalic) and they stoped even better.
