A little back ground on the reasoning. The truck currently has 252,000 miles on it now. Right after I bought the truck I began to notice a shutter in reverse along with a delayed engagement. It started out only doing it under moderate to hard throttle or when backing up a high where more engine torque was being applied. Since then the issue has progressively gotten worse. I performed a transmission service (spill and fill w/ new filter) with three consecutive oil changes hoping that might help. No change in symptom. I let the problem go as long as possible mostly do to the fact that it never seemed to do it in low range. Well that changed this last weekend on a snow/mud run. It started having the issue in low range as well. While trying to back out of snow drifts that I was breaking trail on, the transmission would slip allowing the engine to rev and then suddenly engage and shock load the drivetrain.
So instead of waiting for the eminent dome to occur, I've decided to swap out the transmission. I wan't to share what I found for options as well as ask for opinions.
The options I found are as follows.
1) Buy a rebuilt transmission. At work (dealership) we use a company called transtar industries. They have a re-manufacturing facility back east and would normally just swap you for your core. They didn't have a rebuildable core, however, but would rebuild mine if I pulled it, for $2500.
2) Have a local transmission shop rebuild the transmission. I called a few reputable transmission shops and got quoted around the $2800-$4000 mark if I pull it and they just 'overhaul it'.
3) Replace with a lower miles, used transmission. After scouring local craigslist for one and coming up empty I started calling salvage yards. I ended up tracking a few down that came from some low mile rigs. One was a 95 with 89,000 miles and the other was a 96 with 93,000 miles.
I chose option 3 and ordered the 96. Even though it has a few more miles I assume I may have a few more updates than the 95. I plan to do a basic service on the transmission, filter and fluid, but I wan't to get some opinions on if there was anything else you guys thought I should do to the transmission before installing it. I remember reading about updates through the 3 year but can't seem to find a real reliable source on them, or if the parts are even available still. Any input would be appreciated.
Thanks
Jake
Thanks
Jake
