Opinions...
Anyone have a good reason why I shouldn't do this?
Problem is that my 73 40 sits about 1 1/2" lower in the rear than the front. It bugs the hell out of me so I need to take care of it. It has 4" lift springs and already has extended shackles that are approx 5 1/2" from hole to hole so I don't want to go any longer there. My idea is to fab up new shackle hangers that are 1 1/2" - 2" taller in the area where the shackle mounts to lift the ass end up. I don't want to lower the front so thats out of the question. I don't want to spend the money for new lift springs that are taller because I am eventually going to do a SOA. This will be a temporary fix for now.....anyone have any negatives?
well if you are already going to go soa eventually why not do it now just in the rear? You are already talking about fab work by installing the blocks under the spring hangers which you would probably take off later anyway. Just get a shorter shackle and with the sag you already have you would be just about right. Maybe add a leaf to the front or pull one from the rear to get it to sit level. Some people like it a little taller in the back anyway. Just my opinion
Your lift more than likely came with longer shackles already. If you put too long of a shackle on it can bend over backwards when you excesively flex the spring.
When you do a SOA it will raise the end of the vehicle approximatly 5". If you did a SOA in the rear it would raise it approxiamtely 5" so you would probably want to put the stock springs back on. A lot of guys do a SOA using the stock springs and then run 38".
Would running shorter front-shackles be an option?
or maybe this could be that warn 8274 excuse you where waiting for :D
