Operation flip a hitch
Bentonville, Ark
Soo, I have been thinking for a while about flipping my receiver hitch that I was blessed with on my 80. It turned out to be super easy and looks pretty good as well.
The receiver I have is the kind that is welded to the bottom of the main receiver bar that runs from frame rail to frame rail. I was tired of dragging that thing all over the place and after looking at it decided it would unbolt and flip upside down very easily.
I know some 80s have the receiver welded into the middle of the support bar. I was not blessed by the LC gods to have that kind nor did my truck come with the 4x4 labs bumper I so desperately want!
See you at Moab 2010 (I'll be in the white topped maroon 80)
On to the pics. (sorry about the cell pics, wifey had the camera)
Pic 1 unbolt receiver.
Pic 2 find your favorite sawzall and have at it. I just cut from the bottom up to the first hole in the bumper on the left and right hole and then cut across. I also had to sawzall the chain attach point as you can see. The only thing I still need to do is drill out that plate so I have a place to attach the safety chains.
Pic 3 Finished product -- I also did the spare tire lift mod. Thanks to those who documented that!
I will take some better pics this afternoon. It really was a stupid simple mod that I hadn't seen before. (for those of us with this type of hitch)
Post up questions and l'll answer.
Thanks, Littlerock80.
I had a chance to wheel the rig today for the first time since this mod.
Ran a bunch of trails over at Disney, Ok that I had previously drug the hitch left and right on. Please to say that the hitch didn't touch the ground once! I was really AMAZED how much difference there was.
Cost zero! Gotta love those mods!
Way similar to what I plan to do, except I plan to cut out my rear cross-member and instead of having my hitch bolted to the bottom of the frame rails, I plan to weld it to the top as a new rear cross-member. Then beef it up and add some plate or tube and have a cheap heavy duty rear bumper/receiver.
I just cut out my rear cross member and welded it back in and made a tube bumper around it similar to what others have done here.
I cut about 4-5 inches off the frame rails and picked up a lot of clearance.
Still not finished with it but you get the idea.
Sorry if pics are not that good.
What about chain attachments? It looks like you cut those off?
-Phil
You are correct sir, I just wrap the chain around the main carrier bar for now. I was planing on drilling a hole in the plate below the receiver. I mostly use this hitch to carry my mountain bike. JT
