Only running on 5
ATL. GA.
75 fj40 is running on 5 cylinders I think #6 is the one not firing.
The old dist cap contact were pretty dirty and the rotor button was grooved like maybe it was not pushing in all the way. When old plugs were pulled it appeared that #6 was not firing.
What I have done:
New plugs
Checked wires-ok
New dist. cap
New rotor button.
What next???
Any suggestions? I am thinking that the valves need adjustment and or the carb leaned out some.
So you swapped #1 wire with #6 wire and the number 6 cylinder is still dead?
The valves would not have anything to do with the plug not firing....
Remove the cover and look at the rockers.....If nothing is obvious, start it up and watch them... I had a truck come in with a real mess under the cover a while back....no oil to the rocker shaft assembly...stuck valve/dead holes/poor compression, and all sorts of drama....
