One way juice.
sogncab
Minnesota
I've been monkey humping this idea for a while. I'm going to try and actually make it work now.
My little camp trailer. I 3D printed a box to hold some switches, and a USB port.
Turned out sweet I think. This is just out of PLA, and it's probably version 6.... I'll print the final from PETG
Switches are to kick on the light under the lid, and I want to be able to kick on the running lights, reverse lights, and rock lights underneath on the trailer. Which are just more of the 3/4" marker lights.
I want to be able to power those switches from either the tow vehicle power through the RV plug or from a battery in the trailer.
My concern is back feeding the tow vehicle lights. If I put juice to the running lights or the reverse lights, that will illuminate the lights on the tow vehicle.
I don't want that. All the lights are LED, and don't draw squat. To start with, I'm going to run everything off of a Makita tool battery until I decided what I want to do for power. There isn't a ton of Ah available, and I'm certain power up the incandescent bulbs on the vehicle will drain a small battery way fast. Where as just the trailer, it'll run a very long time on a single tool battery.
I don't know enough to determine what diodes I need to prevent the back feed. This is what I need and would appreciate help on.
Thinking now, I should probably put one on the battery power feed, and the vehicle power feed as well.
I could just unplug the trailer from the tow vehicle, but what's the fun in that.
I am assuming that the power from the tow vehicle to the trailer is on only when the ignition is on. If it isn't, and on all the time, consider adding a relay to allow power to the trailer only when the ignition is on. As for the trailer, maybe a relay or pair of relays that is energized when power is coming n in the tow vehicle? So, when power comes from the tow vehicle, one relay goes off and another comes on? Maybe a SPDT relay would do it. Hopefully this happens fast enough. I'm sure an EE could come up with something better.
Of course, You could make a manual switch setup. But then you have to remember to perform the switcdh LOL!
Currently. There is no power. I still need to wire that in. Along with an RV plug on the 40.
My preference, would be it is always hot.
But a relay and a switch to kill it in the vehicle might be a good idea. I think I've got one for sure, possibly two open holes in the relay block I installed when I did the one that runs all of the aux lighting
Without being an EE. I'd expect that a 1N4005 diode for each circuit would be a good start.
OR could buy a MINI fuse holder block with enough circuits and populate it with these: https://www.waytekwire.com/product/littelfuse-02400104p-1a-mini-diode
That's a really good idea with the fuse holder. I think the j box I bought might be large enough to package everything inside too.
Another idea might be to 3D print a holder for the solder in diodes. I can probably make that significantly smaller
Might be easier yet to do a inline fuse holder.
I'm more likely to be able to pack them in the junction box then.
