One mudders rod end replacement process observations
crholliday
Frisbeetarianist
OKC, OK
The first phase has 3 possible entry branches:
1a. Go get new tires and wait 25 minutes for the assitant manager to come tell you you need to replace the XX rod end and they can do it for you after they order the parts from Toyota for $150.
1b. Go get an alignment and wait for the technician to come tell you they can't align your vehicle because your rod end is fused to the rod and you need new parts which they can get and install for around $500.
1c. Do the front axle tests described in the FAQs here and discover you have play in your steering linkage and decide to replace all 4 rod ends.
2. After carefully searching the archives, you decide to purchase all 4 of said rod ends from either Slee ~$100 or CDan for < $150.
The next phase has 2 possible branches:
3a. Go through various yoga moves to contort your body into the correct positions to get a BFH connected to a pickle fork enough times and with enough force that your rod ends pop free from the various locations they are connected to.
3b. You employ the services of the special tool designed to make light work of your rod ends while smugly thinking fond thoughts of your not so smart cruiser mates twisted up in a knot.
4. As you look at the relay rod - still attached via the steering damper - you suddenly realize you have no way of saving the seals on the damper without using the pickle fork and BFH (since you likely dont have the SST). You also remember that your search results failed to illumate this seemingly obvious hitch.
5. Start a new search for the steering damper.
6. Destroy the damper removing from the rod end and get to work on removing the rod ends.
7a. With all the false confidence you can muster, you rig up some of the most Alabama backwoods rigs ever engineered in your attempt to apply suffiecient torque so as not to:
  • Break your parts
  • Break your tools
  • Break your ass
7b. You use fire
7c. You use a penetrating "catalyst"
7d. You use improvisation
7e. You search more using terms surrounded by profanity
7f. You ask your wife for help
7g. You apply cunning - like a fox
8. You contact Slee to amend your order to include the tie rod and relay rod and chalk it up to an improvement project.
This seems to be a pretty common occurance. Maybe its not common enough for a FAQ, but i do want to get all these tidbits in one thread.
C.
