One dim headlight
Just noticed as it got dark this evening that my DS headlight was out, wiggled the connector at the lamp, the light came back on, but it appeared dimmer or a different wavelength; at least it is not as bright as it's twin on the PS. They are both the Sylvania Silverstars. Really never liked the pattern they sent out anyways and do have a new pair of the JD HIR bulbs sitting around here somewhere for replacements.
Wondering if it is a problem with the harness or connector or the bulb itself. The pair are only 8 months old.
Might be a good time to get the Slee headlamp harness, thoughts??
Thanks; when I put these in 8 months ago I did just that; but will recheck and reclean the connectors when it gets light tomorrow.
If it is a bad harness, now would be a good time to replace it, as I have been planning on replacing the lamps. I've read through most of the John Deere HIR headlight thread; some seem to prefer going to the new harness, but others say it is not necessary. My thinking is that, assuming the stock harness is sound, that it would not be necessary, as the extra light/lumens are from the internal design of the bulb (the HIR coating), not from an increase draw of voltage.
I guess that the bulb could also be dying. I've seen a few get dim or fogged before burning out. The factory harness gets power directly from the battery and uses a relay, so there would be no gain in voltage. On condition that all the components are in good shape. Look at the diagram. A straight connection, battery-relay-bulb.
I currently run HIDs off the factory harness without any problems. It's supposed to be a big no-no but I decided to experiment and if something fails it's going to be a real life experience :-)
Also check the small lead (#6) off the neg battery lead that ties to the left fender. This is a ground point that I have found corroded.
Thanks to all and MikePL for the diagram; all I have had time to do is to wiggle the connector to the lampbulb; nothing else; which seems to point to either a bad wire just before the connector or to the connector itself, or, a bad bulb.
Just wondered if you've managed to figure out the problem? I've got the same issue on my HZJ73. I thought it was the bulb, but I put a new one in today and it is still dim. I'll try some of the other suggestions as well. Thanks.
After a few days I noticed that the lamp was out and wiggling did not help. So I pulled the connector out and removed the lamp. I found that the connector/socket was partially melted and one prong/contact of the lamp was burned/melted off and was stuck in the connector. Not sure why but it shorted out inside the connector leaving the melted prong/contact in the melted socket. Had to get a new socket. That was the hardest part as 99% of dealer parts counter guys don't know how (or don't take the time) to look up the connector type in the separate book just for these parts. I gave him the part numbers that CDan posted, but my parts guy was too proud to accept the numbers, telling me; "you just think I can't handle this--". Well, I thought it, but didn't say it; however my thoughts were proven correct a few days later when the wrong parts arrived. As it was the holidays and I was traveling, the connector went in and worked, even though it was not a duplicate of what was in there to start with.
As others posters have mentioned, checking the grounds would be a good first step, as well as cleaning the connector; taking it apart if you are able may also help to determine if the contacts are bent or corroded.
Seems to be a common theme with the Silverstars! That's what the PO had in mine and it fried both connectors. Hasn't been the same since. I run PIAA bulbs now, upgraded to Slee harness just this week but now seem to have electrical gremlins that won't allow the High Beams to work. The high beam indicator on the dash is dimly lit while lows are on, switch to highs and all headlights go out...WTF?!?
Anyone install the Slee headlight harness?
I installed a Slee Harness at the same time I switched to John Deere headlight bulbs. Less that an hour total, which included trimming the tabs on the new bulbs. There was a huge difference between before and after, but I don't know how much was the bulbs and how much was the Slee harness.
Buy the slee harness.
Put in new lights.
Get a dual batt. setup (big ones).
leave one area on both wires open.
cross the + and - wires while holding to your toungue.
(edit: this is a joke don't try this at home its only suggested for pro.'s such as gray)
Time for HIR's. Installed mine last night using the stock harness and the difference is quite noticeable.
I'm not a big fan of most aftermarket harnesses. The stock wiring gives each headlight a separate circuit, so if one circuit fails the other will continue. The headlight switch even has two sides for the two circuits. Every modern car seems wired that way, I suspect it's required. I haven't seen an aftermarket harness that gives this redundancy. I'd make my own harness if I thought I really needed one.
My slee harness lasted about 2 months...It went out on me after a day of wheeling in Moab. Plugged the stock harness back into the bulbs and have never had problems since.
