Good news, it probably isn't the front diff. Local transmission place told me the same thing. You should read most of "FJ80 Front differential - replace or rebuild" thread.
Let me guess. . . It'll go with the differentials locked, but grinds normal (without the differentials locked).
Diagnosis: Put it in neutral running. Put your ear by one of the front tires, let her grind breifly (or put it in drive). Go to the other tire, repeat. Should be louder on the bad side.
Look up "birfield repack" for more info.
My take: Take off pretty plastic hub cover, then metal hub cap (about 2" dia), & snap ring (need snap ring pliers).
You'll see the flange (female gear, turned by male end of birfield (birfield is fancy name for CV joint or a joint in the axle that can be turned by steering, kind of like a swivel deal on a ratchet)).
6 nuts (only unscrew till end of bolt), each nut has a "cone washer" (cone washer is a super duty lock washer that cones into the stud hole), pound flange (preferably with brass punch ($3 at harbor freight) until cone washer loosens (pound, turn, repeat till all loosened). Finally, take off flange and inspect flange teeth (female) and birfield teeth (male).
I'm still in the middle of mine. One new birfield ($250) and flange ($50), one new flange ($50). Hopefully, your birfs are good and only flange is bad. I bought a knuckle rebuild kit with bearings ($180 from man-e-fre) and am doing the whole birfield repack. Local transmission place quoted $700 to figure out what's wrong. I saw a potential savings, so bought an OME lift kit ($720) from man-e-fre also. I'm up to about $1,500 with heavy duty jack stands, cleaners, torque wrench, and other miscellaneous. But, it should be one heck of a summer!
GOOD LUCK! If your on the Missouri side of the Ozarks you should be smart enough to fix it.
