I've been working with driveline issues for a few days on new to me 93. New ujoints and balance on the rear made a significant improvement.
I then pulled the front and test drove and the rest of the vibration was gone. I have j springs on the lift that came with the truck and while it has the caster correction bushings and tracks/steers well, I was worried I would either have to go with more caster correction or a cv front shaft.
I took the shaft in to a drive line shop recomended by multiple 4x4 shops and others. I told the owner/tech that I had seen a number of references online (mostly here on mud) that the front shaft on an 80 is supposed to be 90 degrees out of phase and that indeed my shaft was that way. He stated that he has seen out of phase drive lines on apparently stock on a number different makes of vehicles but that it doesn't work well with much lift. Because I didn't have much to loose and the pinion and t-case out put were only one or two degrees from parallel, I let him rebuild (new u-joints even though the old joint were still decent and he didn't think they were the problem) and balance the shaft with the joints in phase.
Result no more front driveline vibration.
Just my experience but I wondered what some of you very experienced guys thought, e.g. Cristo, CruiserDan, etc. And I hope if this is a good thing it will benifit someone with the same problem. total cost: $60.00, just the rephase and balance $25.
Best,
Brimley
Best,
Brimley
