By popular demand (which means that 3 or 4 people asked) here is the set up:
Now when my 24V pressure pump comes in I will be good to go I went with pressure pump cause it shuts itself on and off with the water pressure so when you shut the nozzle off it stops and starts up when you turn it back on. If you have any install Q's just ask.
I have the helton in my truck. With the Idle up a little, at 2 GPM it gets to 40* Celsius. using just tap water. I'm planning on improving this by putting exhaust wrap over the heat exchanger so more heat stays trapped in, but for the size of the unit it does ok.
Hoses are a little small though coolant lines are 1/2" and fresh water is 3/8" there is a valve on the coolant to adjust how fast it goes thru. there is no need for the fancy valving matt did on the helton, no matter what you do to it you can not get it hot enough to facilitate putting cold water back in to cool the fresh water down.
Nice find Rob. I'll be interesting to see what they are priced at.
