OME Trim Packer Installation
NB, Canada
Installed some of these on both front and back today. Thought I'd report that it is really easy. 2 hours total time for all 4 corners using basic tools. Jack up one end and place on jack stands. Use jack under axle to compress one corner, install two spring compressors on one spring. Just grab as much spring as you can but don't bother compressing. Lower jack until shock stops rebound. Spring will fall from top an inch or two. Slip trim packer through the spring and work it up to the top. Center the packer and spring and use the jack to compress it. Remove spring compressors. One corner done, on to the rest. All you have to actually remove are the tires.
Would this be considered an inexpensive way to add a quarter inch lift to the OME springs?
