OME Stock Height Replacement Kit
Lynden, Washington
I'm looking at setting up my truck for light towing and offroad use into some of my favorite fishing holes. Have purchased the ARB winch bumper and already have a Warn 12K winch. Thinking of upgrading my fuel tank to something from the land of Oz, maybe 44 gallon size. Rear bumper either ARB or Kaymar for the spare tire mounting features. Tire size looks like a 285 max. Will the OME 861 & 862 springs be the ones to use (spring spacers too?) or should I be looking at the OME heavies? What about the shocks? Are the N73 & 74's as good as Bilsteins? Did a lot of reading thru the search feature and have learned a lot from everyones past projects and build ups. I think I might be getting this "bug" that is incurable!:D I know the :princess: is getting a little suspicious.:D
The "low lift" springs are rated heavy in front and medium in rear. The stock Bilsteins are a good bargin from Autozone. If you are looking to save money I would go with the 861,862 if you are willing to spend a little more the 2.5" springs will not be a regretful buy.
IMHO I think with the weight your planning the OME Heavy 2.5" would be good. Running a 285 with setup would look balanced for a "stock" look. (in other words that lift with a 33" would look like a stock tire with no lift)
With that weight in the front (ARB and 12k winch) and in the rear (44 gal tank, rear bumper w/tire, towing), no expert will recommend the OME stock height springs/shocks. The experts will recommend at least the OME heavies: 850 front and 863 rear.
Don't forget that you will be adding sliders too, so you don't want to be low riding with the OME stock height kit.
Agree with the above. I've run the OME 861/862's and now 2.5" OME 850/860's. With the weight you will be running I would definitely go 2.5" heavies otherwise you will be sagging...
Go ahead and get heavies. Also, I would think twice before going with the "heavy/med" level stance kits. For a good while, I planned on going that route (heavy/med). However, in the long run I figure I will throw enough stuff on the truck to save myself the headache of changing springs etc, in the form of roof racks, rear bumper, swingouts, drawer system, etc
PACN, do you wish you had heavies in the rear? It seems your rig is farely front heavy. Do you have plans for a rack / drawer system / rear tire carrier or swingout / larger gas tank? If you did, would you have gone for heavies front and rear?
I don't have any plans to add additional weight to the rear which is why the OME 860's (mediums) seem to work fine. No regrets with the OME 850/860 (heavy/med) combo with my setup (ARB front, stock rear).
With any added rear weight (drawers/rear bumper) in the back I don't think the mediums would cut it and would defnitely have gone with the heavies front and back, but for now all is good.
I have 861 862 combo. I wish I had gone with 863. I have drawer system that has tools, jacks, camping gear, heavy compressor in back, replaced rear bumper with a spair tire carrier and gas carrier with rack. 862 are just not enough. Go heavies.
