I have just put on a OME lift on my 94 LC it looks like it is leaning to the drivers side a little. The springs had "A" and "B" on them which side goes on the drivers side or does it matter??????
B goes on driver, A on passenger. I foobed mine up and had A/B, it leaned quite a bit to the driver side. I swapped them and it still leans a bit but nowhere near as bad.
If you're dreading having to swap them... get an air wrench. It took me 30 mins to swap the springs (front and rear) with one.
Heh, I realized what I did when I was half done installing the lift but I was too pissed/tired to fix it at the time. I waited a month before I swapped them. Truck handled fine.Ok thats what it is "B" on the pass side on mine DAMN that sux..
I swapped my rears and drove it around for a bit. It still sagged noticeably, swapping the front pretty much cleared it all up.Do a search, there is lots of info on this.
I put mine on a couple of weeks ago. I had the B on the Us passenger side and A on the US drivers side. It leaned to one side just a tad and ARBs answer was to swap the two rear spring only.
I swapped the rear and it site perfectly level so I have my A and B springs installed diagonal from eachother.
Basically, I don't think there is a 'correct' way...its just what ever works. I'd try switching your rears first, put it down and see where you are.
