OME Spring ID Help
Austin, Texas
I'm trying to identify the Dakar springs on my FJ40 that were installed in 2008. I can't find the PN#s anywhere. Perhaps they are no longer made. I did send a note to OME.
I'm trying to determine the spring rate, as they seem way stiff, especially the rears.
The PN#s on the are CS0011 for front and 5AB07 for the rear.
Thanks for the help!
ARB sent me their current docs off their website, which of course do not show either of these part #s.
Any ideas? I replied back to them to see if they had been discontinued.
Fronts are likely CS001F with the F partially obscured/faded, hence why you are seeing CS0011 instead of CS001F.
Out back you are likely looking at production numbers or a production code close to the shackle end. Look just ahead of the differential housing, the actual number to look for is there.
