OME shackle torque spec
Greaseable shackles? If so:
60 lb ft on the side without the grease pin
30 lb ft on the nut around the grease pin
15 lb ft on the nuts on either side of the anti-inversion shaft
Hi All:
Tien, on the OME greaseable shackles I've used on my FJ40 for the last 6 years or so I just tightened down the nuts on the shackle bolts by hand; you don't want to over-tightened the shackle bolt nuts or it will restrict the free movement of the shackles.
Regards,
Alan
"Mustardfj40" asked:
Anybody knows the torque specs for the 2 bolt of the OME shackles?
Thanks in advance.
/td
