OME lift on 07 FJ stock alum rims max tire size
Edmonton, AB
Hi i am sure this has been asked before. I just came accross a sweet deal on some bf mud terrains 35 X 12.5 X 17r just wodering if they will fit on my 07 fj with the OME med duty lift and stock alum rims with out rubbing. And if so will a small spacer plate stop it from rubbing.
Any help is great .
Thanks
you can make them fit, but you will have to do some cutting, search body mount chop or 35in tires a bunch of postings will come up, on what has to be done, I also think you need to drop down your bump stops a couple inches.
joebob is right! I've got 295/75/16 (33.8") on my rig with OME lift plus 10mm enhancers and still have a few rub issues. I can see where it would be a problem, but being ready to cut and you can get them in there.
Who makes the 10mm enhancers, and front diff spacers?
I had the 3" OME heavies all around with 33x12.50x17 Mud Grapplers on my rig with only 1/4" spacers and it never rubbed. If you do the body mount chop you can run 35's without rubbing. Good Luck
you have to do more than just the body mount chop...sure it wont rub on the road but if you actually compress your suspension offroad then yes it will rub...you will need to drop your bumpstops down at least 2inches, plus new UCAs and you might have to do some more shavin down...
Really.... well there ya go. Thanks for the input i learned something. Good Luck :D
