I just installed the medium OME lift (Front 851 and Rear 860) springs; with the front I used the Slee 1" spacer and the total lift was 2.5" in front and 3" in the rear.
The ride height that I want is the front to be even or slightly higher than the rear.
I do have Slee Sliders but no other weight on the truck.
I have the following questions:
Thank you,
Nomad
- With the heavy (850) front springs what lift did you end up with and what was the ride quality?
- Has anyone used the heavy springs with the 1" spacer, were you able to get the caster degree correct; also, did you need swaybar spacers, brake lines, or driveshaft mods?
Thank you,
Nomad
