OME BP-51 setting adjustments
Durango, CO / Virginia Beach VA
Hi all,
2018 LC200
So I installed my OME BP-51 lift a few weeks back and am toying with the settings and was wondering if yall can chime in on
what you guys like and where you have set them too, I no its a personal preference thing but curious to see where you all have ended up with your settings
For now I am trying to achieve a happy medium between mild off road and street driving
The rear end feels pretty nice now but I think i will turn down the rebound a bit on the front
If I remember correctly my compression is set on 3rd from smallest and rebound is on I think 5
I have only adjusted once so far and also wondering how sensitive they are to just one mark in adjustment
Thanks all
Hi all,
2018 LC200
Thanks all
What do you have on your vehicle? Just the lift? Front or rear bumper? Dual batteries? Anything with significant added weight? What’s the front preload at?
What to you have on your vehicle? Just the lift? Front or rear bumper? Dual batteries? Anything with significant added weight? What’s the front preload at?
Bought 2018 LC 200 4 weeks ago had OME installed 3 weeks ago so im stock other than my lift, and 33 inch tires no bumpers yet, slee sliders is next mod running 2722 springs in rear as for pre load im not exactly sure, they installed it straight out of box and it had a bunch of rake so they took them out and adjusted them to make it more level, I have about 3/8 Inch of rake now
I had some problem with rake after fitting an ARB bullbar to my Hilux. There was like 1" difference between front and rear, some guy in the tacoma subreddit told me to get Headstrong 1/2" spacer. Perfect fit and my truck is now leveled. Might need to get aftermarket UCA's tho
