Ok Here it is...I finally got around to putting on my lift that has been sitting in the garage for a couple months. I went with the OME 2.5" Heavy/Med lift. 850 (heavy) springs on the front and the 860 (med) springs on the rear. Everything went on really easy. The only trouble I had was with the nut on the top of the shock on the DS that is under the master cylinder. My advice here is to not worry about trying ot get it off with any "special tools" or wrenches. I took my dremel tool and a cut-off wheel and cut the nut off. Allot less headeache to do it like that than try to actually get it off with a socket or wrench. Nothing is re-used anyway so cut the thing off and move on.... I used allot of PB Blaster on the existing bolts and nuts and everything came apart and went back together very easy. As others here have suggested, I used a tie-rod seperator (pickle fork) n my steering stabilizer and it popped apart with just a few blows with a 3 lb hammer. The ride is much better than it was with the old stock shocks and springs. I have noticed no differences or problems with handling or steering so far.
So I could get a wider stance and not look like it had "chicken legs", I also put on 1 1/4" wheel spacers. They set the tires out even with the fenders for a beefier look.
Ok..... on to the next mods......whatever they may be.......
Comments and suggestion welcomed......... Oh here are some pics too... The first is the before and then after pics....
I also meant to say that although they call it a 2.5" lift, I got a full 3" out of it. I'm sure it will probably settle some but still more than I thought it would be.
to do mine. Mind you this was the first big car mechanical work I've done. Dont have any pics before hand but was similar to Peytonkristen before shot. I think the ride is supperior to that of stock.
wrench so it took me longer than it would most people on here. I spent 4 1/2 hrs on it from start to finish. But that also included some
breaks and other interruptions. This is definitely not a difficult job.
