Old man Emu Light duty
Washington
Hello all,
I have a 2008 GX470 Im going to install the old man emu light duty kit
ome 2884 with ome-90021 up front
ome-2895 and ome-6004
Im curious how much lift can I expect with this setup?
Will I need to level out the front?
pics with wheel size info with this lift kid would be really helpful
Thanks in advance
I have the ome light duty 2" lift from metaltech with the rear coil conversion. Sitting on icon vector 6 wheels with falken wildpeak at3w in 265/70R17. Wheels are 17x8.5, 0 offset. Had to trim a little bit of the inside of the running boards front and back to avoid rubbing but it's not even visible unless you stick your head in the wheel well.
looks great, My wheels have the same specs as yours, my tires though will be a little bit bigger at 285/70/17 so ill probably have to do a bit more trimming.
Did you use any spring spacers up front? Im putting in one 5mm coil spacer on each side because ive been told the lift in the front on the light duty setup is a little under 2''
I used the Toyota secondary spring isolators in the back, and nothing else in the front other than what came with the OME kit except for new kyb strut mount kits. You may have to remove the running boards altogether to fit those tires.
