Hello,
Thought I would write out my plans on a simple old man build of a 97' FZJ80. If nothing more to help see my thoughts in print! Hopefully someone can point out some better ways of doing things too.
My 97' FZJ80 is stock, unlocked with 190k on the old girl. Green and Grey two-tone. 4.10 gears with Cooper ATZs in 265/75/16. The first of September, I will have all 4 new rotors and brakes done. Going with OME. All new belts and hoses. Again, OME. Will have a Detroit locker and bearings, seals done at same time, in rear axle. Taking off running boards and hope to put on Metal-Tech sliders too. 7 pin mod. and CDL switch install. That will be it for September.
Going soon to a 2" lift. But not for bigger tires, but to help keep components out of harms way. Plus, help the approach angles, room for the sliders, and to help with high centering in the snow. Also more room for mounting chains in the winter. My thought is yes, I could run bigger tires without a lift, but I want to stay close to stock rpm and easier on drive train staying with 31" tires. Also thinking that with 190k, springs, shocks, bushings, ball joints tie rod ends should be replaced anyway. So might as well go 2" lift.
I do have a brand new Warn Zeon 10s winch and a brand new ARB twin air compressor to mount when I get a front bumper and mount for compressor. Also, have CB radio and stereo for my 80. Do have lots of tree saver straps, chains, shackles and recovery gear. Of course first aid kit and fire extinguisher. I do have a solar panel and inverter, just need a charge controller.
Next up with front winch bumper will be a duel batteries setup, painless, 8 position fuse panel and relays setup. Then some better lighting for front and a good light to have when backing up in the dark. Air Jacks, air bag jack, great in soft sand and the like. safer than Hi-lift jack. Better tires when I see a deal. Also watch for a good deal on an ARB locker for the front axle. Nice roof rack and snorkel would be great too. Some type of 12vdc fridge and must be something else! Does it ever really stop? Vance.
