OK, so what happened?
I was just driving home, 30 miles into the commute going 65-70 mph, and the engine was making a louder noise than usual. When I took my foot off the gas pedal, it made the noise of staying at a higher rpm for a brief moment then the noise of deceleration. I repeated this several times. The a/c also didn't feel as cold as usual.
I stopped at a store. When I came out, my a/c didn't blow cold, as it normally does, for about a 1/4 of a mile, then started blowing cold again.
WTF???
What was the temp guage reflecting? Is it possible the rig got hot enough reach the AC cutout temp, 226F IIRC per CDan?
Maybe the noise you heard was the fan clutch...Don't know, just throwing out some ideas ;)
Temperature guage was fine, all the guages looked normal when the truck was making the louder noise.
How long have you had the truck and what were the ambient temps?
You will have to help us with "louder noise." That phrase means absolutely nothing without some context. Was it an exhaust noise? Was it a fan noise? Was it pinging? Was it clanking? Were the RPMs higher than expected?
-B-
Did you crash into a Miata?
I've had the truck for 3 months. It has 79k miles on it. Ambient temperature was in the mid 80s.
Everything was fine on the commute in this a.m. The only change I made recently was replacing the two small vacuum hoses on the top of the valve cover yesterday. I tried to replace the PCV valve, but couldnt get it out, so I just left it and replaced the hoses as preventative maintenance.
H
-B-
leto- we still have zero description of the noise. Also, put your truck info in your sig.
Yeah, well that temp guage is not very sensitive...There is a HUGE dead spot when the guage reaches about 1/2 way or horizontal. On my guage that dead spot is about 50F+ wide give or take. My guage reflects about 1/2 way from probably 160F through 215F - Not exact but should be close.
My LX got close to 225F pulling a trailer up a mountain pass and the stock guage only reflected about 2-3 needles widths above horizontal, no where near red.
Just FYI so you don't overly rely on that guage as I would hate to see how fast it moves from "everything is fine" to "you're screwed" temp wise :eek:
EDIT: Watched the stock guage compared to temp on my Scangauge II on my way home tonight...Stock gauge reached its normal resting place (near horizontal), right about 160F give or take. Max temp going home per Scangauge II was 198F and no movement on the stock gauge...
The noise was more of a roadnoise roar, but louder than usual. The RPMs were just above 3k at 70.
Thanks for the info on the temp guage, will keep that in mind.
That seems like high RPMs for 70 MPH. I'm normally around 2400 at 70 MPH.
o/d switched off, perhaps?
