ok, here's a tester
I'm replacing my gauges with Autometers...I have four choices when it comes to Fuel level gauges,
0 ohms empty/90 ohms full,
73 ohms empty/8-12 ohms full,
240 ohmds empty/33ohms full
0 ohms empty/30 ohms full
Which one works for my 79 BJ40? I am running all the gauges off a 12V bus supplied by a 24/12V converter...
Do I need to use an aftermarket float kit, or will one of these gauges work?
According to this from the manual for a BJ40 - None of those gauges will work with the OEM float:
(But the second one is the "closest fit".)
:cheers:
PS. The "Sedan, Coupe, Liftback" wording is an error in the manual. (My guess it that they base each "new manual" on an "old manual for a different vehicle" and then accidentally leave in some of the old wording. I surmise this because I see such errors a lot. Another example is "advising owners to change the oil in the injector pump".)
Autometer does sell a universal sender for the 240-33 ohms gauge for $30....but we all know "universal" doesn't mean fits BJ40...I noticed that the one gauge spec is it out by a factor of two, BJ40-120 ohms empty/gauge 240, BJ40 17 ohms full/gauge 33...maybe there is a way to double the resistance of the 40's sender to match the gauge?
