So I had noticed a slow leak that accumulates right below the access cover to the torque coverter. I researched and found that it could be, most likely, the rear main or the pan arch seal, if I am correct. But I went a quart low while I was on the interstate and stop to buy one at the local conveinance store which only carries conventional. I run synthentic by the way. After I added the quart I have no leak and everything is dry down there. I just did an oil change a day ago with my usual high milage synthetic and am waiting to see what happens. Has anyone experienced the same and if so why run syn if it creates leaks?
and couldn't run synth in the motor w/o leaks before the motor swap...fluid in the driveway.
