[quote author=Seminole link=board=2;threadid=4388;start=msg32788#msg32788 date=1061166224]
:'(Do you see any leaking or seepage top side? Valve cover, block, oil filter, pressure switch? From your pics it looks like it might be the pan gasket.
[/quote]
No gasket, sealed with FIPG (but then Cdan has already said that), even from the factory. The 2nd Oil pan ( the big aluminum thing that runs the full length. It is a pretty common leak. About 6 hours to pull, clean and reseal. That is without pulling tranny. If you need the rear-main done as well, then he is about spot on with the time.
[/quote]
