Oil Weight Issues
Doesnt the manual call for 10w30? What is this 5w30 business????
Hmmm...I wonder....:hhmm:
And yeah, I'm being a smart ass. :flipoff2:
Ok, as promised, here is a video of the start up noise. Turn the volume up and listen closely. A second after the initial start you can hear the noise, but I can't pin point what it is. Also, you will hear the loud whining cooling fan, any advice on why it's doing that? But for 298K and NEVER taken care of, it is commendable how well it runs. I've poured some love into to her the last few weeks. I've been running it everyday and runs great but still needs some more TLC.
Listen closely...
Is it timing chain noise? or oil not getting up to the head quick enough?
Don't forget everyone, I only paid $400 for all of what you feast your eyes on haha. The interior with a good cleaning is almost mint. Everything inside works.
Bump for some feedback on the video I posted in the thread above.
Thanks :clap:
Tough diagnosis to make without really giving your 80 a good close inspection. However, I will still throw a bone to chew on. This is a very similar noise that many BMW V8's exhibit as they get older with age. The interesting thing is that going to a heavier weight oil usually clears up a majority of the valve noise. Seems to be the opposite in your case. I really don't think that the thicker oil is causing the problem directly, but it is taking more time for the thicker oil (I use 10W-40 in Mississippi - PA should not be a problem this time of year) to coat the components up top. So, this leads me to believe that you have an oil transport problem and should start looking at the oil pump. Inspect the housing and see if there are any leaks in the area. Mine was leaking so bad that the belts/pulleys were slinging oil everywhere, namely the alternator. I seriously doubt that a 10W-40 would be the root of your problem or even the larger filter as a contributing factor. I use the larger filter as well.
Also, your fan clutch might possibly be on its way out, but I would definitely check the rest of the cooling system. The fan clutch could easily be a result of a different failed component further up the chain. I just replaced the entire cooling system on my 80 and it was an unpleasant scene at 157K due to the PO's "non-enthusiast" maintenance approach.
I agree that the fan clutch is on its way out. I am super new to these beasts. How do I replace that out? Also I was going to run some sea foam see if that helps. Any other suggestions? Thanks again for the feedback!
The fan clutch is pretty easy to get off - at least mine was. I have read through quite a few threads where guys had a tough time getting the nuts off. Once you get the four nuts off (12mm if I remember correctly) you will then need to basically tap the cones to loosen them, thus releasing the fan clutch/fan assembly. It will be wise to unscrew the two bolts that attach the fan shroud to the chassis in order to slip the fan shroud/fan assembly between in order to get it out. The rest is pretty straightforward. There are quite a few detailed write-ups on the cooling system.
I ran Sea Foam and it did not do much for my 80. However, the Berryman B12 (?) can be purchased at Wal Mart for $2 and some change. It made a noticeable difference compared to the SF, Techron, Gumout, as well as others that I tried.
