- Joined
- Aug 12, 2007
- Threads
- 963
- Messages
- 19,508
Thanks!
sorry ,
i did not click post reply above the other day ...
bellow is correct JIS Pipe Taper T , i prefer Y , its more accurate , because you will locate the OEM Bell Sender later after you complete your build , using the included OEM Service ? DELETE plug , while installing the capillary tube in the side port
when i pipe-dreamed these up a good while back now , i wanted durability factor of stainless steel , but the forgiving give of the softer mauluble brass-alloy
the final perfection level a+ status at the end of the was to have the brass surface treatment electroplated with Nickle ...
i like the fit form and function of this concept and will be applying it to more then few new products coming for the holidays soon
thanks
matt
MADE IN JAPAN Spec. Japanese Industrial Standard JIS J.I.S. PIPE Taper Male & Female Thread Pitch & Diameter For: OIL Pressure Sending Unit T / Y Splitter w/ included OEM Green Loctite Pre-Coated Service / Delete Plug / Cap - VintageTEqParts.com
- MADE IN JAPAN Spec. - Japanese Industrial Standard JIS J.I.S. PIPE Taper - Male & Female Thread Pitch &...
vintageteqparts.com
