oil sending unit
Sweeny, TX
I know I know check the FSM. Its on order I just got the truck.
I need a little help from you guys until it gets here. I need the location of the oil pressure sending unit. I have the new sensor I am currently not getting a pressure reading also I need to know can I test the gauge like a fuel gauge and ground it out if so which way should it go full pressure or no pressure
Thanks
The oil sending unit on my 97 is on the passenger side of the block towards the front. check to see if the wire is attached.
I think I found it on the under side of the oil filter. Chime in if I am in left field with a catchers mitt please.
From a search thread:
IIRC, the sending unit is below the oil filter nipple and constantly gets oil dumped on it. You may want to spend some time cleaning up the area or simply replace the sender with new.
I could be way off here.
OK Pulled the old one installed the new sensor and found one heck of a chewed up wire. Is this common on these engines there is almost no insulation on the wire at all? Also is there no oil pressure idiot light because I am reading no pressure but I have no light on I would think that if there is one it should light up. I can't wait until my FSM shows up I feel like I am asking stupid questions
Did you ever get an answer on the harness? My 91 PO put in andchanic gauge and just cut a bunch of stuff and tspes it back. I tore the old one out and replaced the gauge in the cluster and ordered a new unit. Now I have on stripped wire and another wire with a clip at the end and I’m not sure if the stripped wire just wraps around the post and the clip goes on the tab?
