oil pressure lagging
Longmont, CO
sometimes, when starting the engine, the oil pressure indicator sticks down at *no* pressure. tapping the pedal brings it up to normal range.
does this sound like the behavior of a real mechanical fault, or more like the s***ty indicator is... s***ty?
(I know, I'll check it with a real gauge, but in the meantime I want to know if it sounds dangerous...?)
Oil pressure is measured at 2000 rpm +. At idle ,an older engine is making barely enough to register.
It could be a gauge ,sensor or the oil pressure dropping off which is not necessarily a death sentence.
Even a new engine registers under 10 psi at idle
