oil pan questions
Las Animas, B.C.S., Mexico
Hi from Mexico. Got a 80 series with a 2H installed. Did the swap myself and it went well but didn't upgrade my springs for the extra weight and the bump stops in the springs got beat out. Bottom line, tie rod banged against the oil pan and cracked it. The cracks no problem to weld but what concerns me is the coating on the inside flaked off. How important is that coating and is there a way to repair it? Also , If I put in a set of heavy coils in the front with no lift it will give me about 3.5 inches of travel. with the new bump stops installed will that be enough or should I spend the extra and go for a 2 inch lift?
I wouldn't worry too much about the inside of the pan other than some flakes of the coating coming off, id just paint the outsie of the pan after welding and call it a day. I would check your tierod as well to see if that got bent from the hit
thanks big red for that advice. I got concerned because a mechanic told me that the paint flakes get ground-up passing through the oil pump and can end up in the bearings but then perhaps he's not aware that the 2H has a full flow oil filter rather than a by-pass filter. Do you have any insight into my suspension dilema? If I put in the heavy front coils with no lift do you think 3.5 inches of clearance will be sufficient?
