Oil Level Markings
Ok, I've looked for this, but for some inexplicable reason can't find it. How much oil does it take to move from the 'add' line to the 'full' line? I've recently acquired a 97 80 Series and one of the first things I want to do is watch for oil consumption. Is it about 1 quart? Other?
IIRC, 1 quart.
1.6 quarts IIRC, it is in the owners manual.
I'll have to look through the owners manual again to see if I find it. I sure couldn't find it the first time I looked through. I'll check again.
Welcome :flipoff2:
Make sure you search "oil consumption", there will be some eye openers for you there.
The 1FZFE can use up to 1qt/1000 miles depending on driving habits and oil weight/type with no smoke or leaks.
Dave
found it on page 204 of the LX OM.
1.5 Liter
1.6 Quart
1.3 imperial quart
as a side note to get an accurate reading you are to read it at operating temperature a few minutes after shutdown.
