Oil leak?
I have a '94 FZJ80 with 130,000 miles. After a long drive I've noticed a slight hot oil smell. Inspecting the underside of the engine I noticed an oily spot underneath the rear exhaust manifold on the passenger side. The spot extends down to the oil pan. I had previously power washed the underside of the engine to see where the leak may be developing.
Any thoughts as to cause and necessary fix?
Thanks,
Bob Youngquist
San Diego
Rear oilpan arch seal seems to be the common cause of this.
Based on that descprition, I doubt it. May be a leak coming from the upper oil pan seam (not very common) but the pan arch leak appears along the bottom of the bell housing where the tranny mates up to the engine, and there's nothing down there hot enough to cook oil and give off the burning oil smell. Don't ask me how I know :D.
You need to clean it enough to be sure where it's originating from, then post some pics of where that is.
:beer:
Rookie2
