I have a question about an oil leak I have on our LX450. It seems to have a very small leak and I see oil kind of building up under the spark plug covers. It is not enough to fill up the low spot around the spark plug boots, but it is enough to spread oil all around the low area.
The bigger PCV hose is cracked at the base and a small amount of oil is leaking from there, but it does not seem to be like that much. I know I need to replace both PCV hoses and filter.
Could a bad valve cover gasket cause this?
I think I have attached a photo, but not for sure.
