Oil Filter
Wow, Cdan is selling these filters cheap. I wouldn't think about using an after marker filter, I really dont want to start a debate that's been flooged to death already, However, an oil filter is the heart of your rig. You can slice open as many filters as you like but, what's the true value for your peace of mind. IMO, Toyota is the only way to go, spend the few extra dollars where it is needed most. That's my 2c :)
From what I've read on the web & from what I've seen the 2 highest rated filters including OEM are K&N and Mobil 1 intestingly enough made by the same mfr. Both are synthetic media so they shouldn't break down like the more typical filters. Here are some quotes...
"The Mobil 1 and K&N share the same SPFE rating of 98% but the Mobil 1 has a better multiple pass rating"
"it uses a unique end plate and a thicker can that make it the strongest filter available for wide distribution retail sale. It also uses a synthetic media, which inproves filtration and flow. I'm happy to say that this filter is not a fake. It is definitely a unique design" (Mobil 1)
"Mobil 1 oil and oil filters have long had an outstanding reputation. The filters have a synthetic element media and the strongest shell on the market. The outside shell is .0195" thick on the large ML-301 or .0170" thick on the smaller ML209. Mobil 1 is maybe the most forthcoming with information since for a long time they have been the 100-year-old scotch of quality oil filters. They are proud of their "Hydrostatic Burst" values which are three times the SAE standard. Their "Pressure Impulse Cycles to Failure" values which are the highest, and only ones I have found; which mean the guts of the filter are made like a tank. The whole filter is an engineering exercise in loving design excess"
Oh and the Mobil 1 is a "big" filter compared to the Toyota ones, 3 1/2" dia.
BTW I'm not arguing against the OEM filters just for the other 2. If used a bunch of different filters on a bunch of different vehicles and I've been the most impressed with the Mobil 1. Maybe one of these days I'll sacrifice the $10 and tear one apart.
Just my .02
Just my .02
I'm a big proponent of the factory filters (specifically the 20004), but the truth is in operation there is probably no difference between those and any quality filter, whether it be the Mobil 1, Napa Gold, or other quality unit.
For those that run the non-oem filters, do you guys run the small ones or the large ones.
i used to run a preluber on my truck and a traco rebuildable filter. But the more I modify her, the harder I drive her and I have come to accept that the type of oil filter I use is not the leaste common denominator. I even have a K&N air filter and those are crap.
Just change the oil regularly and run an occasional oil analysis (yearly). If the oil looks good on analysis you dont need to mess with it (including air filter)
Big, the Mobil 1 looks to be about 1.25 to 1.5 the size of the Toyota one.
