Oil Consumption
South Australia
My cruiser uses heaps of oil especially when towing(1L to 100km). I suspect the valve guides are shot as after stopping she puffs heaps of smoke. Which is the best test to confirm this, also best check to test the rings. I am considering the rebuild myself and thinking that if I open the engine up I may as well replace rings and bearings at same time. 4.5L petrol DOHC - 195,000KM - Thanks
I had the same issue and it was the valve guides. I used Clearwater Cylinder Head out of Clearwater Florida for my rebuild. It was around $350 with shipping and parts. To check I would do a compression test and also a leak-down test to confirm where your oil is going.... Valves or rings... Best of luck.
Replace PCV
I see a lot of issues with valve seals/guides and oil rings that are a result of failure to replace PCV valve. There is a lot of pressure in a large displacement I6 that needs to get relieved. If it doesn't via PCV, it will find another way, usually much more expensive than the 10USD PCV valve.
Expost facto here, but worthy of note in the thread.
Scott J
Replacement PVC
Thanks for the advice, I think I will try the PVC first, have read alot about this causing probs. I missunderstood how it works, but after reading some of the other posts it's worth starting here, luck might be on my side, but i'm not counting on it. If not its on with finding where that oils going.
I really think you are expost facto. Bad PCV can be the cause of the problem you describe, but it's rarely a fix after you have the symptoms. It's just included in the fix with the symptoms. I do a lot of engine rebuilds because of innattention to proper PCV. Regardless, give it a try, also make sure all the hoses are clear to and from it. Don't forget to get the gasket with the PCV, you will trash the one you have getting the old PCV valve out. At my local dealer, you order the PCV valve, but the gasket is in stock. Go figure.
HTH
Scott Justusson
94 FZJ80 Supercharged and Sumotoy PCV mod
