I've changed oil on autos a ton, I'm sure past the 1,000 mark. I find it the easiest maintenance item to do and can do it in less than 10 minutes. Well, I messed up today. Being so complacent with this rig and changing oil, I wasn't paying enough attention. I started the rig to make sure there wS good pressure and to check for leaks (thank God!). After about 20 seconds I see a steady stream flowing out the bottom coming from near the oil filter area. I kill it and inspect. See the wire that's resting on the oil filter?
It got BEHIND the oil filter when I installed it! It was between the filter and the block, causing a massive hemorrhage. Fixed the issue and all is well. Just a stupid heads up for y'all!
