ohms on sending unit
Atascadero, CA
what is the ohms rating on a 78 sending unit. i need a new gas guage and i need to know this. if someone could tell me it would save me pulling out the multimeter.
thanks
-miles
I can't tell you exactly but here is some ballpark numbers. You might be better off getting the meter out.
73 ohms empty
23 ohms 1/2 tank
10 ohms full
If you decide to hook up the meter let me know if these numbers where right, thanks and good luck.
From the FSM 98154;
FULL = 17 +/- 2.1 ohms
1/2FULL = 45 +/- 4.5 ohms
EMPTY = 120 +/- 6.5 ohms
dfm
So, from the FSM...
What are the reading supposed to be on the temp and oil senders?
Thanks
From the FSM 98154;
FUEL SENDER UNIT:
And on page 12-28;
Water Temp sender UNIT:
60degC/140degF = 90ohms approx
80degC/176degF = 50
100degC/212degF = 27
105degC/221degF = 23
OIL SENDER UNIT / GAUGE:
The oil pressure gauge measurements on page 12-29 are not straight forward; require a 3.4 watt bulb (which is really kind of vague )... The best way that I can read this is measuring the meter to around 44 ohms (FJ series), 66 ohms for the BJ series. Thats the meter, not the sender unit. If u start the engine and the gauge moves, then the sender is working. U really need to read the instructions on this to determine of the gauge &/or the meter is at fault...
dfm
Sorry for the bad gouge looks, like I was way out of the ballpark.
alright well does anyone know of and after amrket guage that would read that? all ive seen are either 72 full 0 empty or the other way around.
See, that FSM is really worth a bunch when working on FJ40's
